Engine
*CheVyS10*
12-09-2008, 09:05 PM
Ok, so im 17 and taking a major interest in cars. For my senior project in high school I figured why not build an engine. I want to know what type to get, crate or short block. I want a v8 because once i have the money id like to drop the v8 in place of the v6 in an S-10. Eventually id turn it Pro Street. but for now Im just building an engine. So any sugestions?
kiasport
12-16-2008, 08:17 PM
try a Kia
MT-2500
12-19-2008, 10:45 AM
Have a chat with you shop teacher.
He should be able to help you decide.
Good luck
old lefty
01-19-2009, 11:50 PM
hot rod once had a complete how to on building a 350 hp 4.3 V6 not shur what year or month but sounded pretty cool becouse stuffing a V8 could get to be a pain ,plus extra weight bigger brakes ect.ect.
octain01
01-25-2009, 12:12 AM
hot rod once had a complete how to on building a 350 hp 4.3 V6 not shur what year or month but sounded pretty cool becouse stuffing a V8 could get to be a pain ,plus extra weight bigger brakes ect.ect. What this guy said, I had a S10 with a 350, was a pain putting it in, I have seen some 4.3's run pretty good. You can get great power out of a 4.3 as well, and it is a-lot better on gas.
drdisque
01-26-2009, 12:27 AM
What year S10 will you be working with? That makes a lot of difference.
shinta
01-28-2009, 09:41 PM
not to send your head for a spin but if you wont to build a engine for starters a v8 is easy but, if you wont to in press someone rebuild something smaller. and like they said putting a bigger motor in can be a pain.
a friend and i put a 350 in a short bed Isuzu puck up and it was not walk in the park. but i have told people in RL time and time again you dont a lot of power you just need to get what you have to the ground. you have can 600+ hp but if you cant get it to the ground with out slicks then there no point in have that much is the way i see it.
i say rebuild the v6 change the compression and things like that. my cos has a 2000 s10 with the vtech v6 and we pulled it and changed it to a 8:1 compression and put a single t4 troube,forged pistions, titmua valve springs, up greaded cam, and took v8 fuel injectors and swoped then in, and put a piggy back on the ecu and he can out run most mustangs.
but i would talk to your teacher as well he knows where you at and all
