Window Regulator 2door / 4 door ??
cal058
12-07-2008, 07:42 PM
Is the window regulator on a 95-2000 2 door the same as the front 4 door?
Thanks, Carl
Thanks, Carl
MrPink
12-08-2008, 02:44 PM
No, they are different. You have to get the right one.
-Pink
-Pink
cal058
12-08-2008, 10:35 PM
Update,
Just changed out the window regulator out of my 4 door and was able to use one from a two door.
You would think they would be different but it bolted right in.
MrPink
12-09-2008, 11:05 AM
Wow, that's good to know. GM shows those as two different parts, and the windows are indeed different. I wonder if perhaps it's okay to use a 2-door reguator in a 4-door, but not the other way around?
Cool.
-Pink
Cool.
-Pink
doug2060
12-10-2008, 12:44 PM
Hey, That is good to know. I'll find one easier now. They are made really flimsy. My driver side door on my 98 is a pain...
kdameron
01-19-2010, 12:06 PM
I'm going to jump on the coat tail of this post and ask my question. I have a 1992, 2 door, Metro, plain. Does anyone have a diagram of the door frame and window regulator? I removed the door panel and it looks like someone put in a different regulator because there are four roughly drilled holes in the door frame. Any help will be greatly appreciated!
RossT
01-20-2010, 06:28 AM
read this link, everything you wanted to know about metro/swift window regluators
http://teamswift.net/viewtopic.php?f=2&t=17205
kdameron
01-20-2010, 07:02 AM
Thanks!!
