engine swap...RedLine_Celica 03-19-2003, 09:03 PM what should i drop in my 89 celica ST? please, i need realistic answers. somethin not too difficult but i really need more power and aftermarket support. k_dog 03-20-2003, 07:28 AM A Newer ST 1.6 w/less miles. The GT and GTS are wider body and the ST engine compartment will not support much more. Brian phaqgm 03-21-2003, 02:03 AM Originally posted by k_dog A Newer ST 1.6 w/less miles. The GT and GTS are wider body and the ST engine compartment will not support much more. Brian Actually, the engine compartments are dimmensionally the same. You can drop in a 4A-GE, 20v J-Spec 4A-GE or a 4A-GZE without too much hassle, and gain tons of aftermarket support by installing one of Toyota's finest n/a 4 cylinders ever made. Check out Toyosport's engine list (http://www.toysport.com/ENGINE%20LIST%20MARCH%202002.htm) RedLine_Celica 05-09-2003, 10:34 PM anyone know if a 7m-gte would be a possibility at all? without TOO much cuttin and weldin that is. 1G-GTEcelica 05-11-2003, 12:19 AM Correct me if I am wrong but isn't your car a FWD. A 7M-GTE engine is from a MKIII Supra, which is rear wheel drive. So no it wont work unless you do a lot of modifications. Anything can be done with a lot of money but it would be WAY cheaper just to buy a Supra. Unless you are or know a master fabricator it cannot be done. I would just do the 4A-GE or 4A-GZE or you could try and get a 3S-GTE in there but there would be a lot of wheelspin and torque steer. Anyway good luck with whatever you decide. RedLine_Celica 05-11-2003, 10:17 PM if the 7m is a problem cuz its RWD, would the 3s gte have the same problem? 1G-GTEcelica 05-13-2003, 03:45 PM No because in the MR-2 it is mounted transversly like a FWD car. Look in the back of a MR-2 and you will see what I mean. It is a mid-engined car with rear wheel drive therefore it car run a setup similar to a front wheel drive car with the engine mounted transversly connected to a transaxle. Where as the 7M-GTE is mounted "front-to-back" like in every front-engine rear-drive car I can think of. If you were to try and turn the 7M-GTE 90 degrees to mount it side to side you would run into a plethora of clearance problems. You would have to widen the width between the strut towers a foot or more which would create one wierd looking car. The 3S-GTE on the other hand can be mounted in a FWD or RWD position. Not to confuse you or anything but it is small enough to be mounted side-to-side and also has the provisions for an engine mount to be put in a RWD car like my older Celica. RedLine_Celica 05-13-2003, 07:19 PM makes sense. thanks man.:) vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
