1993 Plymouth Sundance drivability issues..Help
KZP1000
11-23-2008, 08:50 PM
Hi, I am having driveability issues on a 1993 Plymouth Sundance 2.2 TBI. It would start but run rough on idle.Checked codes(14: MAP input volt below minimum,25:Idle air control/a shorted condition is detected) Replaced Idle air control, replaced all rubber vacuum hoses, and the fuel filter. Started OK, when you accel. it bogs . Drove down the road to run it up and down tru'auto shifting. Bogged down on hill returning. Stopped and idled, exhaust looked a little dark, and it cantered a little,engine light flashed, checked codes (51: O2 sensor signal input indicates lean mix ratio condition during engine operation. 24: Throttle Position Sensor Volt too high or low. I'm clueless at this point, does not seem like I made a difference. Before repair, there was rough idle, followed by "dieseling" when engine shut off. it seems like the latest code is suggesting to replace the Throttle P S , pretty soon I will be replacing all the junk on the TBI , if it tried to richen the mix too much the Cat.Con.:frown: will clog next.
Any help appreciated..Thanks
KManiac
11-24-2008, 10:17 AM
Sounds to me like the problems with the problems with the MAP and the idle air control may have been masking the additional problem with the throttle position sensor. A malfunctioning TPS will result in the lean condition detected by the O2 sensor. I suggest replacing the TPS, too, then see what happens.
