93 Won't shift out of parktonyfreak215 11-16-2008, 12:00 PM I have a 93 camry that won't shift out of park. I read that it could be the brake switch, but brake lights work. Any other ideas? Brian R. 11-16-2008, 06:15 PM First, you can override the problem component by prying up the cover on the Shift Lock Override Button and pressing the button by inserting a small screwdriver. The cover is above the gear shift position indicator next to the gear shift. It could be any of three or four components. Assuming you have the 4-cylinder engine, access the Toyota AT repair manual here (http://www.camrystuff.com/manuals/Gen3/ax1.pdf). Follow the troubleshooting instructions starting on page AX1-36. If you bring your car to a mechanic, print them and bring these pages with you. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
