Add transmission fluid 03 malibuAmboogie 11-14-2008, 08:01 PM I have looked all over and can't figure out how to add or even change my transmission fluid. Where is it? HotZ28 11-14-2008, 09:38 PM You add fluid through the dipstick tube and remove the pan to change it. BTW, be sure to install a new filter while the pan is off! Amboogie 11-14-2008, 10:10 PM Where is the dipstick, I can't even find that.....:banghead: You add fluid through the dipstick tube and remove the pan to change it. BTW, be sure to install a new filter while the pan is off! wafrederick 11-14-2008, 10:26 PM There is no dipstick tube or dipstick.There is a procedure to do and you remove a plug by the right side axle hear the transmission with a 7/16" or 11mm wrench or socket.It is full when fluid comes out.Most of the newer transmissions are this way,no dipstick tube and dipstick at all. HotZ28 11-14-2008, 11:01 PM There is no dipstick tube or dipstick.What a bummer! :crying: cmhj2000 11-15-2008, 10:10 AM There is no dipstick tube or dipstick.There is a procedure to do and you remove a plug by the right side axle hear the transmission with a 7/16" or 11mm wrench or socket.It is full when fluid comes out.Most of the newer transmissions are this way,no dipstick tube and dipstick at all. Make sure the engine is running before removing the check level plug. If the engine is off 3-4 quarts of fluid will be lost. Of course this might be of benefit for those wanting to do a simple drain and add. :grinyes: tjr19136 11-21-2008, 08:07 PM OK I remember having this problem myself, but one day when i was actually just trying the change my head gasket I saw the red round cap for the transmission fluid...............It under the either the battery post or the air fitter, it takes 1 min. to remove those items. JAMMBluesman 03-31-2009, 09:11 AM LOL, sorry didnt mean to laugh, but i had same prob with my 99 malibu, 2.4l. I just take my to the oil change place like pennzoil or whatever is in your are, TELL THEM to pull the plug and check it while there changing your oil. JAMM Airjer_ 03-31-2009, 11:12 AM Its not as bad as it sounds. However it is important to have the car level (so much for jacking up the front end only) and as mentioned before, running. There is a particular temp range they want you to check them at also. If the vehicle is cold let it idle for 5 to 10 minutes and it should be fine. If its hot there will be more than enough cool down time while your playing with jacks/jackstands/ramps and the seven or eight trips to the tool box. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
