99 escort not getting gas completely
anglhededhpster
11-08-2008, 04:24 AM
MY 99 escort feels like its not getting gas completely when i push on the gas pedal. And it dies sometimes and takes a minute to start back up. i took it to the mechanics and the ran a diagnostic but it didn't find anything. I described what was happening and the said it might be the fuel pressure i think. But i want a second opinion before i pay for something i might not need. I've already had the ideal air control replaced, and the fuel filter , which is waht the said was wrong to begin with, and it still not fixed, so you can understand my hesitation. PLEASE help.
Davescort97
11-09-2008, 11:02 PM
Replace the PCV (positive crankcase Valve). Check that the PCV hose going into the intake manifold doesn't have a crack in it. Check to see that the air cleaner isn't plugged up. If you have over 60k it could need new spark plug wires. It sure sounds like a fuel starvation issue to me. You could try a can of fuel injector cleaner in a full tank of gas. The injectors might be dirty since you needed a new fuel filter. You haven't been taken for a ride. The Idle Air Control and the fuel filter are usually the culprits when you have an idle problem.
