94 Eldorado Code p0012, p0044, p0115scot399 10-30-2008, 04:13 AM Eldo stumbling, missing. Will run but badly. Generated the above codes. Where do I look to fix the p0012 (no distributor reference signal). Suspect that code the base problem. Thanks in advance. DFBonnett 10-30-2008, 07:26 AM The P012 points to the ignition module, the P044 to an O2 sensor, and the P0155 to the coolant temp sensor. scot399 10-31-2008, 09:55 PM Update: changed the Ignition Control Module. No improvement at all, still missing. maxwedge 11-01-2008, 09:13 AM How about a bad plug or wire? Automotive Network, Inc., Copyright ©2013
