My 2000 Sunfire Gt has a miss HELP!!
BigDGT
10-22-2008, 07:53 PM
My Car is a 2.4L twin cam 5 speed and it has a miss in cylinder # 4 and it seems to some and go and thats the strange part because ive changed the coil pack and ive rotated the spark plugs so a non missing cylinder plug is in the missing cylinder and i just replaced the fuel pump and if it was the crank sensor it would not be contained to just cylinder 4 and if it was a vacume leak i dont belive it would be coming and going so if any 1 has herd of this or has any ideas im open for suggestions
Schrade
10-22-2008, 09:08 PM
Did you try switching wires too? (if they're long enough...)
If it's one misfire all the time, the problem is the distributor rotor-to-#4 cap connector, or the #4 wire, or the #4 spark plug, or the #4 spark plug not grounding well in the cylinder head.
Check also for arcing along #4 wire, at night, look for sparking where the weak wire is shorting out somewhere along it's length.
