Posting for a friend...couple questions to people who know their SR20'sdeanjr3 10-14-2008, 08:09 PM Ok, have a friend at work who has a 91 sentra SE-R. he blew his engine, and aquired the engine out of a 94 infiniti G20. my question is this. assuming mostly stock on the SE-R engine, are there any parts that could be swapped out for better performance? IE: cams, intake manifold, ect. thanks in advance. slideways... 10-15-2008, 01:23 PM if the intake manifold bolts right up, use it. but make sure there are no difference in the stuff on the manifold, or modify things so its all there. the earliest SR20s had high port manifold setups which are said to flow a little better. also the early cams are a little hotter and you will gain some power with that switch. ummmm...i think thats the only diffs... Chiquae07 10-29-2008, 02:14 AM if that wasnt the year that they switched from a highport to a lowport, then everything will switch over. no worries. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
