2001 Dodge Ram 1500 leaking coolant in cab and underneath
dodgefan2001
10-10-2008, 11:17 AM
I have a 2001 Dodge Ram 1500 (5.2 liter V8), that has about 178,000 miles on it. I've been going thru a full container of antifreeze about every 800-1,000 miles now for 2 months now, and I've discovered that I'm leaking some anti-freeze from my floor heater ducts and underneath the chassis on the passenger side.
I suspect it's the heater core has sprung a leak, but is it entirely possible that it's a leaky hose or something less expensive to replace? I know a heater core replacement (full works, including flushing the coolant out and removing/reinstalling the dash) is probably going to set me back $750. If it's just the hose, can they just replace that and not charge me an arm and a leg? If I take it in to a repair shop, how will I know if it's the heater core or something else less expensive to fix?
Thought's anyone?
robebert
10-10-2008, 05:27 PM
The hoses and the heater core meet at the fire wall if you do have coolant leaking in the cab bad news for you, needs a heater core
angus10
10-10-2008, 07:12 PM
Yep! The heater core needs to be replaced without a doubt! It's really not that bad of a DIY job, But, you also have to deal with the AC evap core(if you have AC) which you should replace also since you are in there. Check this out,http://dodgeforum.com/forum/showthread.php?t=114317
