94 Camry smoking cat con.
tmarsh
10-08-2008, 06:45 PM
I cleaned up my EGR Valve and Throttle body today. After that I noticed alot of smoke coming from my Catalytic Converter. Any ideas on why. I hadn't driven it very long...don't think it is leaking oil that is burning, but it could be.
Also wondering if this would coincide with a loss in power and a high pitched sound when I accelerate.
A brief history. I have been told by mechanics that I have piston ring wear on one of my pistons. I think I heard it knockin' around, when I was checking the car over after cleaning the throttle body.
The most recent episode of loss of power was noticed after driving on low oil. I noticed nothing in the coolant to make me suspect a head gasket.
As I apply more gas, it seems to be gasping for air. Could it be a vacuum hose leak?
Any help is appreciated.
Any help would be greatful.
Brian R.
10-08-2008, 07:35 PM
Do a compression test on the engine and report the results.
Check your oil for a strange appearance. Do a pressure check on your cooling system. Do a leak-down test on your cylinders.
tmarsh
10-08-2008, 09:49 PM
Had a mechanic do a compression test awhile back. Said cylinder one was not so good, due to the piston ring wear. It just wasn't as bad before, as it is now.
Brian R.
10-08-2008, 10:10 PM
Did he give you the numbers on the cylinders?
tmarsh
10-09-2008, 08:35 AM
I don't remember the actual compression numbers. It was the first piston that had the trouble.
