97 Olds Silhouette power seats don't work.BOL 10-03-2008, 07:41 PM Neither power seat in my '97 Olds Silhouette don't work. The fuses in the dash look good. Is there a circuit breaker or something somewhere that I'm missing? danpletch 10-03-2008, 09:55 PM I've got the same problem in my '98 Olds. I read somewhere to check the wiring under the carpet. Mine is all torn up and I found quite a bit of water in there that I am trying to dry out. You'll need to check the power and ground wires on the connector first to see if you're getting voltage there or a ground. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
