Where is my Thermostat??Idoc198 09-28-2008, 06:13 PM I have a 2001 Explorer Sport Trac with the 4.0L engine. The upper radiator hose is attached to a synthetic housing. Is this the thermostat location? I was sold a rubber O ring to seal the thermostat, but this housing has a flat gasket that appears to be leaking. Do I need a different gasket for this housing? Thanks for any info. way2old 09-28-2008, 07:48 PM Your vehicle uses the "O" ring and not a gasket. Look closely to be sure the housing is not warped or cracked while you have it off. It is located where you described. virgamanda 09-29-2008, 12:22 PM Yes that is it, mine was leaking as well. I had to replace the outlet as well as the seal and thermostat. vBulletin®, Copyright ©2010, Jelsoft Enterprises Ltd.
Automotive Network, Inc., Copyright ©2010
