Pics of my tranny woes... YIKES!
tmartin000
09-28-2008, 08:37 AM
The following is out of my 02 Intrigue with 49,000 miles. I'm not a mechanic but the following is the sun gear issue that a TSB pointed to. The issue is with the missing teeth! Humm, where did they go??
Filter seems to go a fair job. What do you think?
http://i185.photobucket.com/albums/x74/tmartin000/gear2.jpg
Is this bad? :crying:
http://i185.photobucket.com/albums/x74/tmartin000/gear4.jpg
Another..........
http://i185.photobucket.com/albums/x74/tmartin000/gear1.jpg
And finally...
http://i185.photobucket.com/albums/x74/tmartin000/gear3.jpg
Anyway, to a tune of $2500 bucks, I now have a hardened 4th gear shaft, and new bearings, bands, sun gear....bla-bla-bla. Other than slightly gritty, but still bright fluid, and a couple of weird symptoms (sometimes in fwd or reverse at an idle, car would need a little more gas to go) all was dandy........:runaround:
Just thought you guys would appreciate the pics...
Tom
Tobey
09-28-2008, 02:01 PM
Wow. That's a little painful to look at. I can't believe it ran fairly well like that, you'd think once things became that unbalanced, it would just rip itself apart.
Rolm
10-06-2008, 04:16 AM
You know our cars are getting kind of old and worth very little. If i ever have a tranny problem I would not spend $2500 on a fixer-upper ( so-called rebuilt). I would buy from the bone yard for $300 change the fluid and you are good to go.
Hoppy2
10-06-2008, 07:07 AM
I did the "Get the tranny from the wrecking yard" bit once and it bit me in the rear. First one didn't work. Second one didn't work well. Sold the vehicle. I would not recommend getting a used tranny for it. Just my 2 cents.
rncotton
10-14-2008, 01:40 PM
I'm another victim of a tranny failure in a 2000 Intriugue. (with only 65K miles) In my case, it was first showing up as a TCC Solenoid failure. After looking at what was involved to replace the solenoid, I decided to shop it out. I considered a junkyard transmission, but finally decided that since the car was long since paid for and it's the wife's daily driver ... I needed it to be reliable.
$2500 later I had a fully rebuilt tranny with fresh parts, replaced all wear items, upgraded a few things inside, etc ... and a warranty
It's all about peace of mind. I've done the junkyard swaps before, and that's always a gamble. I'd rather not gamble my wife and kid stranded on the side of the road just to save a little cash. It's just money ... they print it every day.
tmartin000
10-14-2008, 08:39 PM
Ain't that the truth! :iagree:
