Misfire - seeking advice
DaveMillar
09-23-2008, 08:55 PM
Hi, I have a Australian 2000 camry wagon. There is a very slight misfire when the the car is not working hard. e.g appears most noticeably when the engine is warm and is on flat or slight decline, with just a little throttle (1500 rpm or so) and in overdrive traveling at 60-80 kph.
I have changed Plugs and fuel filters so far. This has reduced the misfire but has not resolved it completely. Should I try the ignition leads next? Any suggestions would be welcome. It is a 6 cyl, Auto, 170,000 km
I have checked the ignition leads and they measure 14,16 & 18 k ohms respectively. Are these readings OK?
I was told to check/clean the MAF sensor and throttle bore. How do I do this?
Any advice most welcome
Kind Regards
David
somick
09-24-2008, 11:27 AM
Download Factory Service Manual from www.camrystuff.com. I beieve they have everything you are going to need.
They should have the correct resistance for the wires as well.
Good luck,
Sam
solidg
09-24-2008, 07:56 PM
wires
