1989 dodge daytona shelby overheat
rippinshelby
09-22-2008, 07:37 PM
I just bought this shelby and it runs and drives perfect. Except that it overheats. What would cause this and how do i fix it becuase my heat runs way to hot and im starting to sweat
daytonagord
10-29-2008, 08:05 PM
first make sure the fan turns on when car is 3/4 to hot. if no then the relay or coolant sensor is probably bad, if you unplug the 2 wire sensor by your upper rad hose fan shoud turn on in about 5 sec after unpluged, if no then relay or fan bad.
could be thermostat if fan is turning on.
or worst case is head gasket
rippinshelby
10-30-2008, 09:26 PM
The fan was seized up. Replaced it a new universal. Wish the still had the old metal ones!
Scrapper
10-30-2008, 10:11 PM
you can still get metal fan try car quist or napa.
92IROC
03-18-2009, 07:47 PM
I have about 3 or 4 of the metal blade fans if needed...
Also check to make sure the lower valance is in place, it will cause an overheating problem going down the road...
