stripped bolts on brake calibermrbreezio 09-09-2008, 05:50 PM good ole dodge....nothin ever goes right on....tried to change breaks and tried to remove pins from caliber and joy....stripped the bolt instead of loosening them....any ideas how to get em out ? RIP 09-09-2008, 06:03 PM I'm assuming the bolt head is intact and you just rounded off the fascet points. Soak the threaded portion with a quality penetrating oil for at least an hour. If using a 12 point socket try a 6 point socket. Try using a lockable pliers - vise grips. Try an easy out - either the type that fits on the outside diameter or the type you drill a hole in the head of the bolt then insert the easy out in the hole. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
