1990 XJ "Neutral Slips"
JCfromKC
09-09-2008, 09:53 AM
Hey guys I have one that i simply just cant figure out. I have a 1990 XJ 4.0L (AW4 trans) - Problem is while driving that it "slips" like i shifted it into neutral, rpms jump to 3grand on the tack and almost a soon as it started its over. I have found that i can accellerate through the issue and it will stop also. I first though that it might be the Tranny so i replaced it, no dice problem still there, only think i can think of is possibly the kickdown cable may need ajusting or possibly the tranny computer module. Any ideas (anyone else have this problem)
wwwildman
09-11-2008, 06:16 PM
Test the MAP sensor before you look into the trans ECU.
oTHERS SHOULD BE BY SOON to help also
Mike
Mike
knelleken
09-12-2008, 12:15 AM
i think it might be to old for electronic control ? did you use the same torque converter in your new transmission?
just throwing stones
JCfromKC
09-17-2008, 02:26 PM
I changed the torque converter with the Transmittion. I will try the MAP module and see if that does it before i change the ECU.
