1993 Nissan Altima stalls at red lights, What is it?
wh23g3g
08-31-2008, 06:49 PM
I've got a 1993 Nissan Altima 2.4 Automatic. With about 130,000 miles on it. It's recently had a valve cover gasket with tube seals, plugs, wires, cap, rotor, air, and fuel filter. We recently replaced the distributor because I thought that's why it was stalling. The timing is fine it runs good, but after driving awhile it stalls when you stop at a redlight. Take a few mins to start back up with the gas. I thought maybe the coil or igntion control module/power transistor could be the problem. I warmed up for about 45 mins but I didn't want to drive it in case it stalls. Then I checked the power transistor with a voltmeter, it passed with flying colors. I then checked the coil. It passed the primary resistance was 5.1 ohms, the Primary to case winding showed infinite, but failed on the secondary resistance it read 15.1, the max was 12.5 listed in the repair manual. Before I left the house in another car, I checked it again and it had dropped to 14.73, that's after cooling off for about an hour. I never could get it stall just idling. Could this high resistance be the stalling problem? One other odd thing is when I revved up in park I noticed the temp gauge would fluctuate but just sitting still or driving, the needle is pretty stable. Any ideas on the stalling problem?
walt03
09-02-2008, 11:12 AM
Cone on guys give me some ideas!!
This board has never let me down before on ther stuff.
bracketshark
09-05-2008, 11:02 AM
Any codes? I just changed the #1, O-2 sensor on my 97 and that made a world of differance in my idle and gas milage.
hondahawkster
09-08-2008, 07:56 PM
mine was doing the same I put some booster/water remover in the gas ,changed the filter and quit buying gas at wal-mart .It worked on mine maybe it will help you
hondahawkster
09-08-2008, 07:58 PM
also cleaned the mass air sensor
