Code PO1870
chief645
08-31-2008, 12:00 PM
My 1997 LeSabre (150K miles) is giving me a PO1870 code after overdrive engages, this is the only time the check engine light comes on. I can turn the light off and it comes back on again maybe 900-1200 miles later. The shifts in the first three gears are normal. Filter and fluid have been changed recently and I found nothing unusual in the pan. I used Dextron III for the refill, maybe I should have used the new Dextron VI instead. Different listings show my trans to be a 4T65E, however it has a modulator valve which would point to a 4T60E.
HotZ28 has posted in different threads the best thing to do is take it to a trans. shop and have it tested, which I intend to do after the holiday, however I have read that there is a control valve in the vb that controls the tcc and it can be removed and replaced with an updated unit after reaming the hole it went into. I was curious to see if anyone here had made that repair.
With the milage on my auto it may be better to just replace the trans, the engine still uses no oil and gets 30mpg.
gob 455
08-31-2008, 12:52 PM
P01870 transmission component slipping. I've seen this problem come through my shop a few times. The lockup torque converter is slipping. The compueter reads engine RPM and trans RPM, the numbers should be almost, if not exactily the same. If it sees plippage more than 250 RPM (i think), it will set this code.I havent heard of an updated part to fix this but, people are always thinking. The last trans I had come in with this problem, I did a fluid and filter service and added Lub-Guard in the red bottle (it's the only trans additive I use) and they haven't been back sence. But it's my experince that once the converter starts slipping, it's only a mater of time before it fails. This won't necessarily cause the trans to fail complitily, but you will have too remove the trans to replace the converter. You probibily should rebuild the trans if this happens.
chief645
08-31-2008, 03:06 PM
I have heard about lube-guard, in the past I have always used seafoam. Seems lube-guard adds friction modifyers or something like that. I figure a reman trans is in the future at any rate.
maxwedge
08-31-2008, 03:11 PM
The most common cause of this code is a loss of pressure to the lock up as a result of the TCC valve in the valve body wearing the bore it rides in, the resultant loss of tcc engagement pressure causes the pcm to boost pressure to compensate. I'd look into this first. This can be confirmed with a full scan of the trans functions, they make a repair kit to correct the condition that does not require an overhaul.
BNaylor
09-01-2008, 12:47 PM
The Lubegard is a friction modifier additive which may or may not work on this particular issue. The Seafoam tranny treatment is really a cleaning/flushing agent. After use of Seafoam the ATF should be drained out and replenished. Then add Lubegard.
I recall for 4T60E or 65E autotransaxles companies like Sonnax or Transgo make a valve body repair kit to correct the TCC apply problem causing the P1870 DTC.
chief645
09-01-2008, 05:15 PM
BNaylor, thanks for the reply. I have printed some photos and literature from the Sonnax website to show to my trans repairman tomorrow, hopefully he has performed this job before and is aware of the repair procedures.
Jrs3800
09-01-2008, 05:46 PM
Yes the TCC Valve bore can wear causing the Trans to drop out of TCC lock...
Its possible for the TC to be slipping but chances are this isn't the case... The cause could be the Valve bore... As stated there are a couple of kits that will correct for the problem...
Some of the time the 4th gear slip could be the 4th clutches and or in rare cases the 4th input shaft..
In the 2 4T60-E's I pulled apart both of them had pretty well worn 4th input shaft teeth... And on one of them the 4th clutches were burnt..
So there are few things that will cause the slip codes.. Also wondering if you have any idea hot hot the transmission is getting? I have seen 4T60-E's easily get to 230-240F on a warm day...
chief645
09-01-2008, 09:59 PM
I have an infrared heat gun, and on an average summer day the temps are around 200 degrees, I took these readings from the oil line going into the radiator, probably not a good location, but it gave me a base idea of what was going on. I installed a trans oil cooler on another LeSabre I had and the temp drop from inlet to outlet was 30 degrees. If I can get the problem on this car straightened out I intend to install a cooler on it too.
I put around 150 miles on the car today and the light did not come on. I`m going to drain the transaxle tomorrow and add a bottle of lubegard with the fluid change, if this makes no change then it`s to the transmission shop. Thanks to everyone for the valuable info.
chief645
09-02-2008, 02:48 PM
I drained my fluid today and replaced it with Dextron VI and a bottle of lubegard. I noticed my shifts were more crisp and firm, however it is way too soon to see if this change has fixed my TCC problem, I`m not a believer in miracle cures, but hey, who knows it might work. I went to a trans. shop today to have some tests run, when I told the owner what code I had he wanted to know if my truck was a two or four wheel drive, duh, time to find another shop. He said automobiles didn`t give an 1870 code only pickups, wonder how he has stayed in business this long !!!!!
BTW, if anyone decides to go with Dextron VI be prepared to give at least $7 a quart, I was shocked at the price until I noticed it was fully synthetic.
BNaylor
09-02-2008, 03:43 PM
Actually Dexron VI is supposed to be a synthetic blend ATF. I've used it very successfully on '98 and up GM cars with the 4T65E and HD version autotransaxles. I no longer use the old Dexron III.
I used the Walmart Supertech brand Dexron VI for $3.00 per qt. It is just my imagination or does that stuff smell like ginseng to you? Definitely doesn't have the nasty smell of Dex III.
At least we have documentation of an owner with a 4T60E using Dexron VI. Good luck and let us know how it turns out.
chief645
09-02-2008, 03:50 PM
At least we have documentation of an owner with a 4T60E using Dexron VI. Good luck and let us know how it turns out.BNaylor I wish I had checked at Wal-Mart first before buying my fluid, I got Castrol brand at Advance Auto, sure hope I haven`t opened a bigger can or worms by putting this type fluid in a 4T60E, oh well time will tell!! I`ll post again later after I put some more miles on the car and let everyone know whether it helped or hurt. BTW the Dextron VI does smell different from Dex III. Please excuse my mistake on stating that Dextron VI was fully synthetic, I sure don`t want to mislead anyone on here.
BNaylor
09-02-2008, 03:59 PM
Hard to say but many will be very curious about using it in a 4T60E. We have plenty of data it works in a 4T65E before the 2006 model year when GM started using it at the assembly line.
Yeah, I had to go to 3 out of the 10 Walmarts we have in our area to round up 8 qts on the last tranny I did. One associate told me they don't carry it. :screwy: But obviously he had his head up his you know what. For the non believers here is a pic of the stuff.
http://i5.photobucket.com/albums/y186/lizzywiz/DSC09997.jpg
Jrs3800
09-02-2008, 06:33 PM
Yes that guy was an idiot... I work for wally... We have a lot of um, ahh... Really intelligent people...
Wal Mart does sell the Dex 4 but some times its hard to get, and if you can get it you may not get all you need, much was the case with you Bob..
I believe that the products you buy under the SuperTech Brand are actually Penzoil owned by Shell iirc... I have used their Trans fluid for many years, and know people who have used their oil and synthetic oil for 200k... so its decent stuff either was we look at it..
Rasp
09-02-2008, 08:14 PM
Actually doesn't VI mean Dexron 6??? I'm not great at my Roman numerals but I'm sure VI means 6.
And if thats true what happened to 4 and 5.
maxwedge
09-02-2008, 08:37 PM
They can be used on older cars from 2006 down I believe, yes VI is 6, synthetic. VI can be retrofiited to all the previous years.
Jrs3800
09-02-2008, 08:50 PM
Wow... You are right, I hadn't even noticed that... V+1 is 6...
That is kind of confusing, and as it was said... What happened to 4 & 5....LOL
HotZ28
09-02-2008, 10:00 PM
The last time I checked, IV means 4. V means 5 & VI means 6, so I have to wonder if Wally World is using some typical “Goober” associates to label these containers, or are they really selling full synthetic for 3-bucks a qt? I put Mobil-1 full synthetic in my Z28 several years ago, after installing a highly modified 4L60 with a PI 3200 stall (Vigilante) in it. Back then, Mobil-1 cost $7.50 qt.! IIRC, Mobil-1 trans fluid is colorless & odorless (clear as water).
The quote below from the Mobil WebSite;
Applications:
Mobil 1 Synthetic ATF is formulated for use in most North American, European and Asian vehicles.
Approved for Allison C-4 applications
Exceeds JASO 1-A performance standard
Mobil 1 Synthetic ATF is also suitable for use in vehicles that specify the following fluid requirements:
Audi G 052 025-A2, G 052 162-A1
BMW LA2634
Esso LT 71141
ETL-7045E, ETL-8072B, N402
Ford* MERCON*, MERCON V, MERCON LV
All 2005 and earlier GM vehicles**
Honda ATF-Z1*
Hyundai SP-II, SP-III
Idemitsu K17
JWS 3309
Kia SP-II, SP-III
MAN 339F, V1, V2, Z1, Z2, Z3
Mazda ATF-III, ATF-MV
Mercedes-Benz 236.1, 236.2, 236.5, 236.6, 236.7, 236.9
Mitsubishi Diamond SP-II, SP-III
Nissan Matic-D, Matic-J, Matic-K
Subaru ATF
Toyota T-III, T-IV
Voith 55.6335.XX (G607, G1363),
Volvo 97340
ZF TE-ML 03D, 04D, 09, 14A, 14B, 16L, 17C
*Not recommend for CVT applications, Mercon® SP, Ford Type F** Mobil DEXRON-VI ATF is recommended for 2006 and newer GM vehicles and improved performance in 2005 and earlier vehicles, wherever DEXRON is specified.
BNaylor
09-02-2008, 11:46 PM
The Walmart Supertech Dexron VI is not mis-labeled and it says meets the requirements of transmissions calliing for Dexron VI and meets the GM Dexron VI specification. It is the real deal but at a cheaper cost. It is a synthetic blend and not a full synthetic. :rolleyes: Made from base stocks and advanced additive technology. See link below which shows Mobil's version of Dexron VI. You need glasses Shep or are you hard of hearing? :lol:
Click here (http://www.mobiloil.com/USA-English/MotorOil/Other_Products/Mobil_Dexron_VI_ATF.aspx)
chief645
09-05-2008, 08:55 AM
Click here (http://www.mobiloil.com/USA-English/MotorOil/Other_Products/Mobil_Dexron_VI_ATF.aspx)Update on PO1870 code and change over from Dextron III to Dextron VI.
I now have 325 miles on the Dextron VI fluid change over and so far, no problems. The color and smell of the fluid is the same as new, and the shifts are so much better, but this could be because of the lubegard I added along with the fluid change. I had the "fishbite" problem before the fluid chage, but now that has disappeared. I will update at 500 miles.
BNaylor
09-05-2008, 09:12 AM
IMO no. It is the Dex VI. This is the most common result when people switch over to Dex VI from Dex III. I did not use any Lubegard additive in any of the GM cars I did the switch and the shifting is very smooth. On mainly the 2-3 and 3-4 upshifts you can barely tell and have to watch the tach. Keep us posted and good luck!
BNaylor
09-07-2008, 11:44 AM
Mixing of Dexron VI and Dexron III. Any comments?
Supposedly the two fluids are compatible. Obviously you won't get all the old Dexron III out when doing a pan drop service or a fluid exchange service when switching over to Dex VI. But there seems to be misinformed people on the Net that think the two can be mixed as a matter of routine maintenance like top off situations when the ATF is low and other situations. I read that people with Dexron III equipped autotransaxles are using Dexron VI to top off their trannies or mixing them in greater quantities. Doesn't this defeat the purpose? The classic comment is the container says it is OK to mix the two. :screwy:
chief645
09-07-2008, 01:10 PM
Supposedly the two fluids are compatible. Obviously you won't get all the old Dexron III out when doing a pan drop service or a fluid exchange service when switching over to Dex VI. But there seems to be misinformed people on the Net that think the two can be mixed as a matter of routine maintenance like top off situations when the ATF is low and other situations. I read that people with Dexron III equipped autotransaxles are using Dexron VI to top off their trannies or mixing them in greater quantities. Doesn't this defeat the purpose? The classic comment is the container says it is OK to mix the two. :screwy:I agree with you BNaylor, mixing the two together would appear to defeat the purpose. I think my transaxle still had nearly 4 quarts of Dextron III in the converter, I hated leaving that much inside, but had no way of getting it out. To date I have almost 500 miles on the change over and still no problems or CEL. Tuesday I have to make a 450 mile trip back to work, if the CEL is going to come back on it should on that trip as it will be interstate travel (75-80mph).
BNaylor, i just bought a software/hardware product that enables me to hook my laptop to the DTC on any OBDII compliant vehicle, the information pulled from the ECM is remarkable. Where should I post a thread explaining how valuable this tool is for troubleshooting? BTW, this tool showed my trans to be running at 170 degrees at 65mph, much cooler that with the Dextron III.
BNaylor
09-07-2008, 01:26 PM
Probably less than that in the torque convertor. Maybe 2 qts. Rest is in the radiator, pressure/return lines, etc. Some of us added a pan drain plug to do a subsequent drain and another resupply with Dex VI. Also, if you remove the 1-2, 2-3 shift accumulator and open it up you can get about another quart out.
Glad it is working out for you so far. :thumbsup:
Good investment on the odb-ii program. It will pay for itself. I use Autotap with a Dell laptop and a Powertuner since I mod GM cars with the 3800 engine.
Feel free to post at our Buick Tips & Maintenance forum.
Good observation on the cooler tranny operating temperature. I noticed that too.
Blue Bowtie
09-07-2008, 01:38 PM
To me, the whole concept of "synthetic blend" defeats the purpose. Why not use pure synthetic base and the appropriate additive package to achieve the desired result? I've got M1 in two of my 4L60s and a TH700-R4 with a buttload of miles and haven't so much as looked a a mounting bolt, just regular service. One of them pushes a 4,600 pound barge to 13.6 in the ¼ mile, so it isn't like it gets babied.
BNaylor
09-07-2008, 02:05 PM
I don't know abut that Jeff. I tried M1 in my GTP which is not exactly a barge around 4 years ago but with the moderate mods pushes it to high 12s in the 1/4. Check out my timeslip. I was getting slippage and my ET went to pot. Hard to dial in for ET bracket racing. Dumped the M1 and back to the Dex III and no issues since. I do not use Dex VI in my GTP but I have converted several other daily driver GM cars to include my wife's L36 '99 Regal LS and my '01 L67 Regal GS to Dex VI. However, keep mind these are all with the 4T65E and 4T65E-HD autotransaxles in which you do not want to take any chances.
chief645
09-07-2008, 02:28 PM
Good observation on the cooler tranny operating temperature. I noticed that too.AutoTap is what I bought, too.
BNaylor
09-07-2008, 02:31 PM
Excellent! What do you think of the virtual gauge display? My primary virtual gauges are air/fuel mixture and knock retard (KR) because my GTP is supercharged with boost mods.
chief645
09-07-2008, 04:13 PM
Excellent! What do you think of the virtual gauge display? My primary virtual gauges are air/fuel mixture and knock retard (KR) because my GTP is supercharged with boost mods.I am having a ball with this tool. I`ll drive a few miles then stop and change gauges to check other areas of my auto. I had to change the speedometer cluster last year, AutoTap caught this and showed me how many miles were actually on the vehicle. I plan to go ahead and buy the enhanced parameter software so I can dig deeper into the ECU. The virtual gauge display is great, my ole laptop is really coming in handy now.
chief645
10-18-2008, 02:08 PM
I wanted to post an update on the PO1870 code I mentioned earlier. I now have 3,200 miles on the car after converting over to Dextron VI trans fluid. The transaxle is shifting great and best of all no trouble codes have popped up pertaining to trans/converter problems.
My advice to new members--listen to the moderators on here, they know what they are talking about.
