96 v6 fuel pump and/or relay issue
TPyles
08-26-2008, 09:14 PM
Hey guys, I just got a 1996 chevy with a v-6. I got it not running, the guy had it at a shop and they wanted a ton to fix it,they said it needed a fuel pump, so I got a sweet deal. I got it home and got it ready to change the fuel pump and then I looked at the relay under the hood in the fuse block. They had a jumper wire from a hot to the relay, I hooked it up and it started right up and it ran perfect,but turn the ignition off and it still runs, wont stop till you pull the wire.
I am thinking maybee its not a fuel issue and its an ignition swithch issue? Any ides? Its got 230,000 put sounds perfect.
TPyles
09-02-2008, 09:14 PM
It was the ignition switch, I changed it from the key to the main harness.It takes about an hour and the part retails for 245.00. I swapped it out and it runs great.
