no gear engaguementThe_Mechanic_33 08-25-2008, 04:39 PM 2002 dodge neon 2.0L vin C. sitting at stop light and tried to go but engine just rev`ed. No pcm,body,or trans codes.scanner shows gear selections are being commanded and linkage is fine along with fluid . I do however see on scanner that turbine rpm is 0. das2123 08-26-2008, 08:16 AM So you checked your fluid level and it's good? If so, then it might be time to change the filter and fluid. The_Mechanic_33 09-03-2008, 08:14 PM trans was toast rebuild and all is good. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
