1999 S10 Blazer Suspension Pop
rontomed
08-24-2008, 07:11 PM
My suspension pops at times with the steering turned all the way in either direction. My mechanic says the ball joints are good.
4x4 blazerguy
08-24-2008, 10:37 PM
I have a 1997 4x4 Blazer that does the same thing. It also does it some when I hit the brakes hard. I believe it is blown gas shocks. I have the OEM shocks with 93,000 miles. I have been meaning to change them just haven't got to it. If I push hard on the front end in a downward motion I notice it rebounds then there are a little bounce. On a good shock you should be able to push down hard & only get a rebound. Check yours & see what happens.
Once I do I'll post the results.
rontomed
08-25-2008, 06:25 PM
I installed new shocks last week.
Ultrashock
08-25-2008, 07:51 PM
check your torsion bar mounts
rontomed
08-25-2008, 08:10 PM
My 99 Chevy S10 Blazer is 2wd. I believe that only the 4wd units have a torsion bar.
blazes9395
08-26-2008, 03:40 PM
Could be a few things. Check you idler arm, and your pitman arm, make sure both are tight and not worn Make sure your a-arm/control arm bushings are good too.
