2001 tahoe cooling system leak
View Full Version : 2001 tahoe cooling system leak 2001 tahoe cooling system leak tahoe4x4guy 08-23-2008, 04:29 PM Thanks tahoe4x4guy j cAT 08-24-2008, 12:46 AM My 2001 tahoe seams to be leaking aintifreeze from one of the lines which is underneath the truck on the right hand side just past the rear tire. It`s bolted to the bottom of the truck and the line runs in through the rear inside quarter panel. If any one mite have the repair procedure to fix this .Could it possible be a seal. Thanks tahoe4x4guy THIS IS ANTIFREEZE !!!!!?????? check again.. exwldr 08-24-2008, 01:33 AM sounds like a heater core leak... remove the inside trim panel to find the problem. might just be a minor thing like a split hose. exwldr..:sunglasse tahoe4x4guy 08-25-2008, 08:56 AM I did check the rear heater core.What i did was pull it out of the case but left it hookup ran the truck and it didn`t leak.The only thing that confuzes me is the coolant or antifreeze in the recovery tank in the front is red but the leak in the rear is green. roadrunner2 08-25-2008, 02:27 PM What color is the refrigerant? Related Links Participate in thousands of discussions at AutomotiveForums.com! Registration is absolutely free. |
