1986 Chev 1/2 ton PU 350 700R4 Tranny
juggie#1
08-20-2008, 10:01 PM
I'm having problem with Transmission leak at the oil pan I'v change the gasket three times, it leaking in the frt part facing the engine, I know it not leaking from the seal all that's new, and I lay down under the truck while it running, after I stop it start to leak more, even snug the bolts around the pan, I also try to seal it with silicone, how can I tell if it building up pressure to cause that or if the pan is bad. I'm lost please help. THanks
maxwedge
08-21-2008, 08:30 AM
It is possible the pan sealing surface is distorted, take it off lay it down seal surface down on a flat sufrace and make sure it is not bent some, as I said, usually this is the problem.
