ground connectionyalvonne 03-12-2003, 04:09 PM I have a 1997 ford ranger ext. cab. I cant find a place to ground my amp. everywhere i have tryed didn't work. It needs to be within three feet of the back cab. thanks for the help. fordman123 03-14-2003, 07:20 PM Sheet metal cutting screw through the floorpan would be the likely choice, given the circumstances. Good Luck fordman123 03-14-2003, 07:20 PM Or you could ground it at the rear seat anchor bolt. contagionxlt 01-09-2004, 08:18 AM use a self tapping screw the size of the ring terminal on your grounding wire, attach your driver to your drill and ram it through the floor with a washer between the carpet and the terminal. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
