1995 lumina 3.1L TBI (FUEL PUMP)
ynotpay
08-19-2008, 11:26 PM
replaced fuel pump, it ran for a while the now it wont start; no power to the fuel pump, I hot wired the pump and it works. before this I had the famos run and stall. please help why dont I have power to the pump?:banghead:
jeffcoslacker
08-19-2008, 11:31 PM
Fuel pump relay...check fuel pump fuse too if you didn't already
jeffcoslacker
08-19-2008, 11:33 PM
Here's the answer to your next question...I'm psychic :grinyes:
Relay - Fuel Pump
On your 1995 Chevrolet Lumina-Sedan/Coupe 3.1L SFI OHV , the Relay - Fuel Pump is located: http://www.autozone.com/images/template_images/clearpixel.gif
Under hood, passenger side, front side of strut tower, mounted in relay panel above fenderwell
ynotpay
08-21-2008, 02:46 PM
replaced fuel pump, it ran for a while the now it wont start; no power to the fuel pump, I hot wired the pump and it works. before this I had the famos run and stall. please help why dont I have power to the pump?:banghead:I checked the fues for the pump and its good, tried diconecting the neg post to battery over night and then re-connected it with the key in the ignition, also could it be the ignition module; if so is it in the distributer? I just cant find it. Plus the fuel relay????? is it the one passenger side way inside mounted alone on fire wall above the alternator, or which one of the three relays is it mounted twords the the front passenger side by head light???:confused:
