94 Z28 Camaro Leak
Paul94Z28
08-18-2008, 09:27 PM
Hi-
My 94 Camaro has a leak(several - but lets take one at a time for sanity's sake). The leak happens right around the ac compressor. I put dye in the p/s fluid and there is some of that as well as a little coolant.
I have narrowed down part of it (coolant) to leaking only when the heat or AC is on, leading me to the heater hoses. There are expensive. Any good sources?
The p/s part is trial and error, I thought it was overheating so I added a cooler. All connections are dry, but it is leaking from somewhere... I started replacing hoses and that is adding up.
I pride myself on this engine being clean, that is why I am so finnicky about it.
Anybody else go through this?
I will get to the other leaks later...
Paul
Paul
