View Full Version : AutoTrac II in my 96'?
1993Suburban
08-17-2008, 02:58 AM
I have recently flushed out the fluid in my differentials, and now it is time to do the transfer case. Will it harm my transfer case if I use GM AutoTrac II in it? I realize this was designed for vehicles with AutoTrac transfer cases in them, but I have heard it is still good to use on older vehicles. I believe it is somewhere around $7 a quart at the dealer. Thanks.
MT-2500
08-17-2008, 09:22 AM
If it is not a automatic transfer case I would stay with the dexron 111 fluid.
Lube Gard makes a bottole of red additive for dexron 111 that would give it a little better lube.
MT
1993Suburban
08-17-2008, 05:14 PM
It's a push button activated transfer case. I'm assuming that's not an automatic transfer case then, correct? Should I go with synthetic fluid? I suppose I'll just stick to conventional. I have used Lube Gard in my transmission with good results, I will pick some of that up and add it. Thanks MT.
MT-2500
08-17-2008, 05:31 PM
Unless you shift buttons has a auto button it is the old regular transfer case.
There is a tag on back to id it.
On the one that calls for dexron 111 my info says not to use synthetic fluid or the new gm type 6
transmission fluid in them.
If you can not find any more dex 111 carquest has the mercon/dexron fluid.
Get the lube Gard red bottle for dexron 111 fluid.
MT
1993Suburban
08-17-2008, 05:47 PM
Cool I'll go take a look at the case number so I know how much fluid to put in it. Conventional Dexron III and Lube Gard it is. Thanks.
MT-2500
08-17-2008, 06:35 PM
241 transfer case K1500-K2500 sub takes 4.6 to 5.2 pts.
Fill it up untill it runs out the top filler hole.
MT
Related Links
Participate in thousands of discussions at AutomotiveForums.com! Registration is absolutely free.
