Change tire size on 99 Questbull33 08-15-2008, 07:06 AM I have a 1999 Quest with 15" tires (P215/70R15) on factory steel wheels. I would like to change the wheels to 16" alloy wheels. I have an opportunity to buy the wheels from a 1998 Nissan Altima (tire size P205/60R16). My question is will they fit my 99 Quest? oldblu65 09-02-2008, 07:17 PM Go to www.tirerack.com (http://www.tirerack.com) , they will show the specs for your original wheels and tires and the specs for the ones you want to install .If they are the same and the offset is the same , you'll have your answer .You can also talk to them and " pick their brain " for more info . Good Luck !:smile: Automotive Network, Inc., Copyright ©2012
