96 3.3 Voyager trans R & RTwinscrew 08-11-2008, 08:35 PM My friend has this 96 voyager van 3.3 and is loosing fluid (Trans) big time. Upon inspection fluid can be seen dripping from between engine and trans out of inpection shield. OK, We need to change the frt. tranny seal, Right? good, We are going to remove the trans from the bottom and leave the engine in supported by a floor jack. Any tips not in the Haynes book ? Is there going to be a problem getting trans back onto engine because of convertor or any other unforscene surprises ? We need to get this done ASAP due to his other car is a motorcycle and it"s about rainy season here. Than You for any help... :runaround: :screwy: Vitor Vilela 08-13-2008, 12:55 PM Hey.. I'm on the same boat, same van and same year. Started same way, the only problem I'm having is to drop the transmission. Can't release the back mounting bolts... Any ideias to remove the bolts will be appreciatted.. Thanks vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
