2006 R/T won't shift out of parkDarth Dickey 08-11-2008, 02:07 PM It appears to be jammed just after the shifter slides out of the park position. The shift lock works great, and after I step on the brake, it allows the shifter to move but that is where it stops. I need some input on to what could be causing it to stop where it does. This is driving me crazy:runaround:, and I need to know if I need to just lubricate it or buy a new tranny (or rebuild one, one or the other) tyrant33 08-12-2008, 10:15 PM I know that there is a fix for this. try doing a search at www.chargerforumz.com I think that there is a clip or something right under the bezel that if is not connected it causes that proiblem you're having Darth Dickey 08-12-2008, 10:20 PM that was what it was. The first couple of times, I had to use a screwdriver to disengage it and then it fixed itself. Might be a bad solenoid or switch that was preventing it from disengaging, but we are having it looked at soon. Thanks man! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
