Misfiresdhodson2004 08-07-2008, 08:44 PM 1996 Jeep Grand Cherokee 4.0L Hi. I am having engine problems. I get the check engine light after driving a short distance. The codes are: P0300 (Random/multiple cylinder misfire detected) and P0301 (Cylinder 1 misfire detected). It runs fine in park or neutral. It shakes and runs rough in drive with the brake on. I describe it as chugging. It smells like a snowmobile. About a month ago, I did the distrib, distrib cap & rotor, plugs, wires, fuel filter, and set the timing. It ran great during that time until Sunday. I picked up a snowmobile and it overheated. The radiator blew near the bottom. I did the radiator, water pump, and thermostat yesterday. I did the plugs again yesterday. The insulators were red/orange. I also did the wires today. The plugs helped about 87%, wires made no difference. Not sure what is next. Thanks in advance for any help! reekor 08-08-2008, 08:16 AM Compression test? You might have a bad head gasket or head from the overheat. 1996 Jeep Grand Cherokee 4.0L Hi. I am having engine problems. I get the check engine light after driving a short distance. The codes are: P0300 (Random/multiple cylinder misfire detected) and P0301 (Cylinder 1 misfire detected). It runs fine in park or neutral. It shakes and runs rough in drive with the brake on. I describe it as chugging. It smells like a snowmobile. About a month ago, I did the distrib, distrib cap & rotor, plugs, wires, fuel filter, and set the timing. It ran great during that time until Sunday. I picked up a snowmobile and it overheated. The radiator blew near the bottom. I did the radiator, water pump, and thermostat yesterday. I did the plugs again yesterday. The insulators were red/orange. I also did the wires today. The plugs helped about 87%, wires made no difference. Not sure what is next. Thanks in advance for any help! dhodson2004 08-08-2008, 11:02 PM Just borrowed my brother's compression gauge today. I'm going to test it tomorrow after work. Head gasket was my thought. I'll post the findings. Thanks. Compression test? You might have a bad head gasket or head from the overheat. dhodson2004 08-10-2008, 01:49 AM I did the compression test. Cylinders 2-6 read between 120 and 150 psi. Cylinder 1 read 70 psi. So it needs a head gasket. When I bought the Jeep, I couldn't tell if the valve cover is leaking, or the head. I guess it is the head. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
