junk fuel level sensordfrederick5 08-07-2008, 05:02 AM fuel guage started out working only until it got to 1/2 tank then would drop to empty, now even when tank is full it drops to empty moments after starting the car, wondering if i am correct assuming the fuel level sensor is junk. Any advice would be appreciated! slls 08-07-2008, 12:19 PM Replace sender. dfrederick5 08-07-2008, 03:31 PM would that be located on the fuel tank thanks for your input slls 08-08-2008, 12:14 PM Yes, and should able to just purchase the sender, not the whole unit. dfrederick5 08-09-2008, 01:05 PM kinda wondering since some cars have access to the fuel pump underneath the backseat would it be advisable to cut a hole to access the fuel pump with a tin snips, just an idea crazy enough to work slls 08-10-2008, 11:59 AM I have never done it, I just drop the tank. Not that bad, with pump working you can at least drain it. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
