95 Sub 4WD-ABS Front Wheel Speed Sense
View Full Version : 95 Sub 4WD-ABS Front Wheel Speed Sense 95 Sub 4WD-ABS Front Wheel Speed Sense jjwg3 08-05-2008, 11:40 PM Any input appreciated, Thanks!! John 1995 Suburban LT 4WD MT-2500 08-06-2008, 09:20 AM All codes are for front wheel speed sensors. Check wiring and connectors and for rust build up on sensors. Clear codes and see what comes back first. jjwg3 08-07-2008, 09:56 PM You were right. I cleared the codes and only the 25 came back. Looks like the left front wheel speed sensor. Makes sense as I had to change the right front wheel senser a couple years ago. Thanks!! JT MT-2500 08-08-2008, 09:04 AM You are welcome. The code says open circuit . Check wiring and plug in real close. Good luck MT Related Links Participate in thousands of discussions at AutomotiveForums.com! Registration is absolutely free. |
