97 jgc 4.0 system alarmjuancito6 08-04-2008, 06:13 PM i was reading others post and every body says cut the purple and yellow wire where is located this?:runaround: legalfee 08-05-2008, 01:14 PM Ground the purple wire inside your drivers door juancito6 08-05-2008, 02:48 PM i already check inside drivers door one bunch of wires it came from the control doors and the other from the mirror outside the door the other is inside who control the motor of the others doors juancito6 08-08-2008, 12:55 PM there is not purple and yellow wire inside the door it only a purple and black wire at the controls door help me please is a 97 jgc 4.0 legalfee 08-08-2008, 01:24 PM To temporaily disarm the alarm just use the key to lock/unlock a door. To disarm permently I've heard you can ground a purple wire in the drivers kick panel/door. Also this was posted: You can disconnect the factory vtss, but you have to have the jeep running. The module is behind the dash to the right of the radio.You have to take the right side of the dash apart. There is a module about the size of a pack of cigarettes it might be black or a reddish color. If the jeep is running,unplug it and let it run for about 2 minutes.Then the pcm should "forget" about the alarm and it should be good to go.You can leave it unplugged.If the jeep doesn't start,you obviously can't do this. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
