'98 Mirage turn signal probs.zronmm 08-01-2008, 06:06 PM I am helping my Daughter in Law with her '98 Mirage, and the turn signal does not work. I've Chk'd the fuses, relays, wiring etc..I've tried Chkng The Combi-Switch on the column, but I don't know what to chk! Please help as She has already received a ticket from our local P.D. DFBonnett 08-02-2008, 08:12 AM If you switch the flasher on, does it light up and not blink or does it not light up at all? Have you checked all the bulbs and sockets for corrosion? sparkeykev 10-03-2008, 05:55 AM I am helping my Daughter in Law with her '98 Mirage, and the turn signal does not work. I've Chk'd the fuses, relays, wiring etc..I've tried Chkng The Combi-Switch on the column, but I don't know what to chk! Please help as She has already received a ticket from our local P.D. chech the hazard switch isnt partially on also check hazard switch operates lights if not could be faulty flasher unit vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
