1993 Cavalier, 2.2 L, 4 cylinderralph48 07-31-2008, 11:32 PM How do you replace the ignition module? Is it best go get it from under the car, or over the top of the engine? I am going to replace the plug wires also. Anyone have any pictures of this? I will submit pictures after I do the job. I want this car to last to 200.000 miles. J-Ri 08-02-2008, 07:07 PM If it's got the A/T, you have to do it from the top and side. M/T I'm pretty sure would be a piece of cake from below. I found it much easier to remove the passenger wheel and get to some of the bolts from there. The CKP sensor is mounted to the ignition module, be very careful not to break it off inside the block, I hear it's a PITA getting it out of there if it breaks off. I've only done one and I got lucky :) vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
