lancer 2.4 gts turbo release leak
Google
Web AF
omnipotent343
07-31-2008, 10:29 PM
there is a rumor going around the net that there is going to be a turbo coming out mid august for the 2009 2.4L gts lancer. if so i want it. and i was wondering if any one else heard about this or if any one knows any further information about the turbo please let me know i.e. were i can buy one, how much horse will i have, what will be the time added on the 0-60 ete.
thanks, your input and information is appreciated :)
fullmetalpanic
08-19-2008, 10:50 PM
RoadRace Motor sports has one out right now....
You can email Rock about it, hes loads of help with anything. He could answer all the tech questions about how much you would gain. I didn't really look at it closely to tell ya the truth
http://www.roadracemotorsports.com/
However its not just about bolting the turbo on
You need a turbo. - Pick one that will meet your goals
a new exhaust manifold - pick one that has the correct flange for your turbo
a custom down pipe - make sure it bolts to the 02 housing off the turbo
custom intake preturbo piping. - mandrel bent.
custom post turbo intake piping
intercooler and more piping with correct BOV flange
BOV
Tap a flange in the oil pan for your custom oil return line
figure out a way to run pressurised oil to your turbo and custom lines for that.
Depending on turbo choice you might need to also run engine coolant through them
Some way to hack into your ECU and tune. Emanage or AEM stand alone would work
Quality gauges: Think DEFI
. Boost
. AEM UEGO WIDEBAND
. EGT
. Oil Pressure
A way to log what the fuck your engine is doing.
A better clutch.
Larger radiator
Boost controller
Vacuum line
Wire taps
Good luck... we have some guys who wants one another forum whos looking for one. We are trying to talk him out of it... only cause hes 16 and inxeperinenced. Well what can you do?
Google
Web AF
