1997 to 1998 engines
Google
Web AF
Bubbagnh5
07-31-2008, 07:41 PM
I need to swap my 2.4L Cavalier engine with my 1998 Sunfire 2.4L engine can I just swap the engines or is there more to it than that?
Thanks
Bubbagnh5
wafrederick
07-31-2008, 09:05 PM
One thing is to check the knock sensor and I know a trick up my sleeve if it is differant.it maybe the long wire one or the one wire screw in.If it is the long wire one,make a threaded bushing and tap a 8mm x 1.50 hole in the center of the bushing,same with the outside thread,tap that one to thread of the old style knock sensor.I have a warning on the 2.4: Do not turn backwards.Turn the crankshaft as you are tightening a bolt only.If you turn it backwards,you bend the valves.Pull the crank pulley and remove the bottom mount,you have more clearance when getting it out and in.
Classicrocjunkie
07-31-2008, 10:35 PM
96-99 Z-24's - same options
00-02 same options.
Google
Web AF
