94 camry stalls
mikefar84
07-31-2008, 01:41 PM
I have a 94 camry that is stalling sometimes. I was driving it down the highway and i turned my ac on and it started acting like it was going to stall. When I turned the ac off it stopped. Sometimes it wont start right away in the morning. And when i get it started it eventually stalls. I have replaced the spark plugs and the distributor.
It has 115,000 miles on it. I replaced the entire distributor. I also replaced the wires and it still does it. I had a problem with it a couple months ago and I ended up needing a new distributor. Could the distributor go bad that quick?
somick
08-01-2008, 11:33 AM
We need more information about your vehicle: mileage, manintenance history.
Did you replace entire distributor or only a cap?
If spark plugs, wires and distributor turn out OK, the next suspect would be the fuel delivery system.
Sam
jdmccright
08-01-2008, 01:21 PM
I'd also check the timing. As the belt stretches, the camshaft can lag behind the crankshaft...or it may have skipped a tooth.
DFBonnett
08-02-2008, 08:21 AM
Was it the same problem that replacing the distributor corrected? I'm assuming that the "new" distributor is a rebuilt. Some are known to be of poor quality.
mikefar84
08-02-2008, 12:21 PM
no, it was a different problem. It wouldnt even start then.
jdmccright
08-03-2008, 12:21 AM
After all that, check the IAC valve that is supposed to kick the throttle up a bit when the A/C is turned on...could be a vacuum leak or loose hose.
