Ignition trouble?ken_man_1 07-31-2008, 08:58 AM 2000 Chevy 3500 4door Vortec 7.4 Gas (forgive me, I don't remember which digit is engine code.) 4x4 Auto trans Air cond. Just had engine replaced due to spun bearing on the crank. About 2 months before, it will spudder and misfire intermittently, throwing no codes whatsoever. I have tested the truck with the scanner during driving and in the shop. My question is, how do I test the ignition module? I did a full tune-up, then rechecked everything, but problem still exists. ken_man_1 08-08-2008, 09:56 AM I replaced the Ignition Module ($108), and that cured my problem. j cAT 08-08-2008, 04:58 PM I replaced the Ignition Module ($108), and that cured my problem. make sure the plug wires are of the proper resistance ...if the ignition wires are arcing this may have caused the module to fail/....the other reason would be very high miles.... vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
