Blower motor dying?1968 Pontiac 07-27-2008, 07:11 PM On my 92 k2500 when I turn on the fan the volt gauge drops well below 14 volts. I'm wondering if this is normal or if the blower motor may be dying. Is there a way to check the blower motor? This truck doesn't have AC (or any other power options), and last year I installed a rebuilt Delco 85amp alternator. Thanks. MT-2500 07-28-2008, 02:34 PM Does it blow air as normal or slow down? Dash gauge readings are not very good. Always check voltage at battery or fuse box. A amp meter will check amp draw on blower motor. Is it poping any fuses or resistors? MT 1968 Pontiac 07-28-2008, 06:45 PM Does it blow air as normal Yes or slow down No? Dash gauge readings are not very good. Always check voltage at battery or fuse box. A amp meter will check amp draw on blower motor. Is it poping any fuses or resistors?No MT See replies above Voltage at the battery measures 14.08 at idle & no blower. Voltage at the battery measures 13.96 at idle & with blower set at high speed. What is the correct way to measure the draw? MT-2500 07-28-2008, 06:50 PM You need a good volt/amp metere to read whatamps it is pulling. your battery voltage is good. If not blowing fuse or resistors packs and the blower is blowing good. I should be ok. MT 1968 Pontiac 07-29-2008, 07:01 PM Thanks MT. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
