1993 Camry Won't Start
lightningr6
07-21-2008, 10:48 AM
Girlfriend got up to go to work this morning, car wouldn't start. She has intermittenly had problems with this. Sometimes the battery is weak, other times its not. I go outside while she is trying to start it, and I think I hear a click, I think it is a dead battery. I start my car and put on the booster cables , still does not turn over. I am beginning to wonder if the click I heard wasn't a spark from an unsheathed wire when the system is energized.
I have 3 other possibilities.
1) Bad ignition switch. It has had service work for this before.
2) A shorting Park/Neutral start switch. Which by the way will not start in Neutral.
3) Short somewhere.
Can someone shed some light on possiblities.
somick
07-21-2008, 11:58 AM
I would start with checking all the contacts. Especialy the battery and grounds. If that looks OK, I would check batteries voltage. Suppose to be around 12.5 volts. The same voltage suppose to be on the starter contacts. Sometimes a whack on the starter with a hammer solves the problem. Then you know that this is your starter that gives you problems.
Good luck,
Sam
jdmccright
07-21-2008, 12:53 PM
If a load test on the battery turns out okay, then check the alternator and the connections between it and the battery. Poor charging will also drain the battery eventually.
DFBonnett
07-21-2008, 02:45 PM
It sounds like bad contacts in the starter solenoid. Here's a link on how to repair......
http://www.4x4wire.com/toyota/maintenance/starter/
Brian R.
07-21-2008, 06:27 PM
See also the FAQ thread on this topic.
