1990 vette fuel problemchuck amala 07-19-2008, 02:55 PM :confused: my 1990 corvette quit getting power to the fuel injectors. it will start if i pour gas in and will die when gas burns up! Blue Bowtie 07-20-2008, 07:10 AM The standard L98 should have two fuses which supply injector power, marked INJ1 and INJ2. Each bank of injectors should get power from one of these fuses whenever the ignition is turned on. The ECM controls the grounded side of the injectors, providing a ground path whenever either bank of injectors is supposed to "fire." The first thing to do is determine if the injector harness has the 12V supply with the ignition on. If there is no 12V source present, check the fuses and harness. If there is 12V, check the injector harness and ECM. The VATS system will also prevent the ECM from pulsing the injectors if the system does not detect the correct ignition key resistance and signal the ECM. The VATS can also prevent the starter from operating, but there are separate VATS circuits for each of these functions. One may be working, while the other may not be. chuck amala 07-20-2008, 01:19 PM both fuses are good Rimmer 07-20-2008, 01:54 PM Did you check for fuel pressure? chuck amala 07-20-2008, 03:38 PM No but thats my next move chuck amala 07-25-2008, 02:54 PM :wink: I found the problem, one of the fuel injectors fried ,causing the ecm to quit sending messages to injectors. Replaced ecm ,disconected bad injector until I get new injectors. It runs a little rough on 7 cylinders but it starts.. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
