Where is located the ATS Silverado 2003andreval 07-19-2008, 09:26 AM I would like to know where is located my ATS ( Air temperature Sensor) or the CTS ( Air coolant Temp Sensor ) on my Chevrolet Silverado 2003 4x4 5.3L engine. any picture will be greatly appreciated. Andy:smile: MT-2500 07-19-2008, 11:16 AM Air tempt sensor is usually in the intake air hose/air filter. What is the problem with it? Most problems with them s it being left unpluged after service work. Look for a wiring plugin around intake air duck work or air filter unpluged. MT andreval 07-19-2008, 11:24 AM I would like to put a resistor across it. I can either put it on the ATS or the CTS (coolant temperature sensor) It is probably easier to put on the CTS. Do you know where the CTS is located. Thanks Andy andreval 07-19-2008, 11:26 AM Air tempt sensor is usually in the intake air hose/air filter. What is the problem with it? Most problems with them s it being left unpluged after service work. Look for a wiring plugin around intake air duck work or air filter unpluged. MT I would like to put a resistor across it. I can either put it across the ATS or CTS. Do you know where is the CTS is located Thanks Andy MT-2500 07-19-2008, 12:04 PM Leave it alone if it is working. Putting a resister on it will mess up the fuel mix and erngine running and is illegal. http://www.epa.gov/air/caa/title2.html#iia http://www.epa.gov/air/caa/ http://www.epa.gov/air/caa/caa203.txt http://www.epa.gov/air/caa/caa205.txt vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
