97 Blazer Horn Not Working....
heydawgg
07-18-2008, 11:23 AM
Hi,
Just wondering if anyone has encountered this issue with a 97 4x4 Blazer.
Horn isn't working.....
*I've checked the following:
*Actual horns under the hood....they honk when you run a dummy wire to the battery....those are good.
*Replaced the relay in the glove box.....
*When I press the horn button on the wheel, I can hear the relay click, so I know it's not a horn button issue.
*It seems to be something goofy between the relay and the actual horns....
Any ideas??
Thanks!
Heydawgg (Rob)
Any ideas??
Thanks!
Heydawgg (Rob)
MT-2500
07-18-2008, 01:22 PM
Can you blow the horn from horn wire at relay?
Will grounding the horn button wire at relay blow horn?
Swap out relay
Swap out relay
Cgroh89
07-18-2008, 01:24 PM
Did you try to run a jumper wire from the relay to the horn? For stuff like this I have a 20 foot jumper in my tool box to test out circuits this way you can find if the wire from the relay to the horn is shorted
