Transmission shifts from 1 -2 then N
Ralph50
07-17-2008, 11:25 PM
Hello All,
1993 3/4 ton van, 5.7L, 177K miles, transmission suddenly just stopped shifting into 3rd gear, now just goes to N or slips. My none transmission trained mechanic said that they checked and no fault codes and all solinoids we activating during the testing.
Could it be something else, cause I will probably scrap the van if the trans is bad. Should I pull the pan and look around?
Ralph
Ralph
MT-2500
07-19-2008, 08:52 AM
Yes pull the pan and check for any metal in pan and filter.
Also go over it with a good transmission capable scanner.
Check for codes and read out transmission data and post back any transmission codes,
MT
MT
Ralph50
07-19-2008, 08:53 PM
Hello,
The mechanic read the codes and tested the soliniods in the trans. he said he could hear the soliniods clicking so he said the problem was internal.
R
R
MT-2500
07-20-2008, 09:33 AM
Was there any codes?
Did you get a good transmission scanner on it?
Have you pulled the pan and looked in it or run a pressure test?
