Tranny fluid leak
Google
Web AF
Capita08
07-17-2008, 09:14 PM
So I just bought an 86 trans am/fire bird, rebuilt engine/tranny, original 305 turbo.
After moving it to my house, I noticed that it started leaking fluid under it, by morning, it was a huge puddle..
Im hoping its just a simple thing like loose spngs or gasket, what else could it be though?
Pretty choked atm.
Hoping this aint gonna cost me a fortune to fix as I alrdy splurged on the ride.
72chevelleOhio
07-19-2008, 03:33 PM
If you didn't have a puddle, then you ran it, shut it off with no leaks, then came back a while later and had a puddle. I would say its the front seal in the trans. Not too expensive if you do it, but a PITA to do IMO.
Morley
07-19-2008, 03:41 PM
So I just bought an 86 trans am/fire bird, original 305 turbo.
Huh? No such-a-thing as a 305 "turbo".
Check your speedometer cable atthe transmission and see if it is wet with fluid.If it is then the seal at the speedo gear is leaking, they generally only leak when the car is sitting still, not running and it takes aa while before it starts doing it after driving it.
Capita08
07-19-2008, 07:07 PM
305 Block, 350 Engine
Cable Aint Wet, Will lift the car today and check it out.
Morley
07-19-2008, 09:27 PM
Can't be that either. A 305 block isn't interchangeable with a 350 block, the 350 is a much larger bore and you can't bore a 305 out that far.
Try removing the dust cover and see if it is wet up under there.
72chevelleOhio
07-20-2008, 04:17 PM
I thought he meant 305 engine with a 350 turbo trans....but I missed the "original" part in the post...
Morley
07-20-2008, 06:30 PM
Well, I got no clue what the heck he means, but what he says makes no sense and is impossible.
Google
Web AF
